Firmware 1.5.0 - Print Quality Degraded After Update (Improved After Downgrade + Full Recalibration)
Support replied with a solution but I’m not in a position to test it:
Sounds like an AI response.
Just go back to 1.4.1 until they sort it out.
Is there any reason not to be on the Paxx firmware?
I can see no reason for not flashing with Paxx firmware. I would suggest doing a full calibration after installing Paxx firmware.
I’m still catching up on this thread, but this isn’t great. A new mesh should not be required to have the correct z offset, assuming the last mesh is still valid.
Personally, I am reluctant to update to a newer firmware unless it is confirmed this is no longer a strict requirement.
Actually, I think I misread this.
Bed level and calibration are required after update. Are they also required with every print? (That would be strange.)
I agree. I strictly use adaptive mesh leveling. This always replaces the last known mesh.
I don’t want to try out and guineapig the latest firmwares just to find out my setup doesn’t work anymore.
For what it’s worth, I think I misread Zoe’s post. She seems to just be saying a one-time recalibration is needed after the initial update.
I hope your right, I think I’m gonna sit on my hands at least until PAXX releases his next full/stable release as it all feels alittle rushed atm?
Yes I agree. It honestly feels a bit like a lottery right now. I hope the next update will take care of it and not introduce new issues. Or maybe has better documentation in case some things need to be done after an upgrade.
For what it’s worth, I personally perform all calibration steps after each upgrade. And yes I use upgrade and update interchangeably :sweat_smile:
I guess you’re hinting that not all updates turn out to be upgrades! :laughing:
They get upset about the distinction between “upgrade” and “update” in the Linux world, but it’s a fine point and a bit like the geographer’s idea that a mountain less than 1000m high can only be a hill.
I haven’t really made a distinction between these two terms either. I guess I’ll need to pay more attention to that going forward.:+1:
@Wombley Yes, previous firmware updates didn’t require redoing bed leveling and calibration. Versions 1.5.2 and 1.5.1 are a one-time exception this time.
Right. They are required only when you first update the firmware? Not before every print?
1.5.2 coming
“U1 Firmware V1.5.2 Beta Testing is Now Available”
Please clarify: is that before starting any print, or only the first print after updating the firmware (and when changing the print plate)?
I’ve interpreted it as the first print after firmware update, but the clarification I’ve requested should resolve the matter.
Why not link to the original post? Now it looks as if you wrote this text :sweat_smile:
Original post by Zoe M here:
I think it would be better to wait for someone else to test it first. :))
Edited your post, you did quote that post without quoting and it seemed you are snapmaker staff.
I would like to share another experience I had.
On firmware 1.5.2, I was able to print successfully using the 0.2 mm Quality profile without any issues.
Then I switched to the 0.16 mm High Quality profile, and the first layer became poor again.
Without changing any settings, I simply turned the printer off, turned it back on, and started the exact same print again. This time, the first layer printed perfectly.
This makes me think the issue is not related to the model, filament, or slicer settings, since the exact same file and settings can produce either a bad or a perfect first layer after simply restarting the printer.
Hi, is the new firmware 1.5.2.12?
Can you share some first layer printing pictures and export the system log on U1, then send to the technical support:https://snapmaker.formcrafts.com/u1-troubleshooting-request
Best regards
