Hello Snappies,
I started printing with Eryone Silk PLA at 210 degrees. First print went well, next day it stopped extruding half way. Thinking the nozzle was clogged I tried to unload the filament which strangely didnt work. Tried loading it to push it along which didnt work either.
I then opened the module and tried removing the hot end when i discovered that the filament had expanded at the end of the feeder tube that leads to the hot end with no way to remove it.
It’s jammed in tight, I tried to heat a needle and push it through but that made it worse. There are also no bits that i can grab with pliers.
Any idea’s? Luckilly I still have my warranty.
