# Extruder nozzle grinding into prints
**URL:** <https://forum.snapmaker.com/t/extruder-nozzle-grinding-into-prints/40760>\
**Category:** U1 Troubleshooting guides\
**Created:** [December 31, 2025, 1:25am UTC](https://forum.snapmaker.com/t/extruder-nozzle-grinding-into-prints/40760 "2025-12-31T01:25:33Z")\
**Showing post:** 21
**Post date:** [January 16, 2026, 5:14am UTC](https://forum.snapmaker.com/t/extruder-nozzle-grinding-into-prints/40760/21 "2026-01-16T05:14:42Z")
I remember the knobs under the heated bed are quite tight; they’re usually only used when you need to perform bed leveling. But the bed is usually leveled one time at the factory before shipping.But I don’t think this is what’s causing your issue.
Still, I’ll add the steps just in case.
After the bed is mechanically leveled, you normally only need the software-level compensation from now on (see image) and won’t touch the mechanical knobs again.
 ![image](https://us1.discourse-cdn.com/flex022/uploads/snapmaker/original/3X/2/a/2a49e0dbf26a63e22cb9b12a5f1ac7c0d1e36aab.png)
before mechanically leveled start ，you can printing the adjust tool：[U1 加热平台螺母套 - 免费 3D 打印模型 - MakerWorld](https://makerworld.com/zh/models/2111321-u1-heated-platform-nut-sleeve#profileId-2284241)
 ![image](https://us1.discourse-cdn.com/flex022/uploads/snapmaker/original/3X/4/d/4d38efbe71ae24f736d770865ccfd16b924d43f8.jpeg)
than fllow step in machine：
 ![image](https://us1.discourse-cdn.com/flex022/uploads/snapmaker/original/3X/4/c/4cacfdbd1b8efbd41df5a0345f27810538bdf21c.jpeg)
 ![image](https://us1.discourse-cdn.com/flex022/uploads/snapmaker/original/3X/d/1/d1b2418529001e95c4c8f849ebb418fae64af8b7.png)
 ![image](https://us1.discourse-cdn.com/flex022/uploads/snapmaker/original/3X/d/1/d17827e5a9ab7e6aafb98b0735c288872abdd97d.png)
Tips:
1. When deviation is large, adjust in 1/4-turn units.
2. When close to target, switch to 1-3 mm units per nut rotation.
_[View the full topic](https://forum.snapmaker.com/t/extruder-nozzle-grinding-into-prints/40760)._
