Export/Print Printer Settings
#1
Is there a way to export or print the settings for a setup? (.txt, .cvs, etc…) Want to move the settings from one machine to another without having to type them in manually…
#2
Which settings? The snapmaker calibration, or the SnapmakerJS print settings?
I’m not aware of a way to do the first. I know it’s possible to export and import some of the print setting in Cura. I don’t see any way to import or export the Snapmaker3D or SnapmakerJS print settings.
#3
The print setting on the right hand side of JS. Speed. Bed temp, material temps, etc. and yes Cura does let you.
#4
It’s on the to-do list; hopefully we won’t have to wait too long.
#5
You always could write your settings into the config files. You just have to be careful when you update snapmakerjs
#6
That is rather unsatisfactory when one has multiple profiles.
#7
Now that I’m getting calibrations working/setup for different materials, it would be great to have more material settings saved also. I almost never use the PLA/ABS buttons… I’m always on the custom and have to type in my numbers each time…
That would save time also.
