Error: Unable to generate G-Code for this model
#1
can-not-generate.stl (182.9 KB)
I was able to generate this .STL from tinkercad.com, but when I open it in the latest version of Snapmaker and hit the Preview I get the error “Unable to generate G-Code for this model”.
Does anyone have any idea? I can add shapes to the item and it will generate code for the shape, but not for the logo.
Thanks in advance for any help.
#2
@psellers
Dear Paul
Try to make thicker walls (0,8 or 1,0 mm maybe work). I think Snapmakerjs can’t handle single wall extrusions well. I tested your model with Simplify3D and tere I have no problems.
Michael
#3
Copy of Empty Syscon.stl (631.0 KB)
Hello Michael,
Thank you for the suggestion. I followed your recommendation and the item now prints with no problem.
Paul
#4
Is Simplify3d worth the money? Of course I have the software provided by Snapmaker, but would anyone recommend Simplify3d? Is the output better?
#5
If you want to dig deeper into 3D printing Simplify3D is worth the money!
Snapmakerjs is a free basic tool that works for the basic needs.
You can download Cura for much more options on a similar UI.
But for me Simplify3D is the top class software for 3D slicing! It’s a very powerfull tool…
Since you have many more options the output can be better than with the provided Snapmakerjs.
#6
Most of the users are not capable such errors due to several restrictions. To overcome these errors Sign In 0x87dd0006 they need some fruitful suggestions to sort out easily.
#7
skip snapmaker for slicing and use cura.
#8
Skip cura 4.1 and use Cura 4.2 Beta. It had lots of bugs for me. The beta works as well as 4.0. . .
