Error after using variable layer height
After a couple of attempts trying to use variable layer height to smooth my layer this errors keep appearing, saying that to use the tower, the objects need the same measurement, and they are the same, so I don’t understand what is going on. Is there any expert who has more experience in this topic
I think variables layer height does only work with similar objects or only with a single object because orca needs similar layer heights for the prime tower.
Delete the copies. Do the variable layers on the remaining object, then copy-paste. The copies will inherit.
