Enclosure Options do not appear
Hello,
I just built my Snapmaker Enclosure up and have one issue with it:
The manual shows an extra point „Enclosure“ in the menu, but this is not appearing in my control. I already checked the cables and the restarted the system but it didn’t work.
Does anybody have an idea what I could do?
Thanks!
Hi buddy,
I have encountered the very same issue and the solution is easy - you need to upgrade firmware. Just download it, save to USB, plug in to machine, run the file and it will appear.
T.
Thanks! That worked perfectly.
Thank you Darkscraper,
same issue and any information from Snapmaker.
Thanks a lot, now works like a charm.
Fa
