Enclosure door sensor causing errors with 3d printing
#1
Hello,
i have a reproducible error with the Enclosure. When i use the 3d print function and have the door open and then close it, the 3d print errors out and messes up the print. When i remove the RJ45 plug from the door sensor, printing goes fine. BTW i think i use the latest version of the software 2.5.1.
Regards,
Laurens
#2
Hi @Laurens You need to connect your computer (which should have the latest Snapmakerjs version 2.5.1 installed) to your Snapmaker (which should be updated to the latest HW version 2.7) via USB cable and establish a connection. Then in the Settings of Snapmakerjs you need to toggle the door detection (Enclosure) to ON.
