Downloads and Updates
#42
Apr. 3: V2.5.4
@all
Thank you for your suggestions to make Snapmakerjs better. Here comes the latest version. Your feedback is always appreciated. Please post bug reports and feedback to this topic: Bug Reports and Feedback for Snapmakerjs V2.5.X =)
Release Note
Change Log:
  • Added G-code estimated execution time for laser and CNC
  • Optimized G-code generating time
  • Fixed the bug that extrusion is too little when using v2.5.3 to generate G-code
Snapmakerjs for Mac OS
Snapmakerjs for Windows 64 bit
Snapmakerjs for Windows 32 bit
Snapmakerjs for Linux 64 bit
Option 1 (Recommended)
Option 2
Snapmakerjs for Linux 32 bit
Option 2
Snapmaker 3D bug on mac - Software does not start
#43
Jun. 13: V2.5.5
@all
Release Note
Change Log:
  • Massively improved software performance when loading and slicing 3D printing models.
  • Added custom installation on Windows. You can specify install location of Snapmakerjs; Future upgrades on Snapmakerjs will not erase your custom 3DP settings and uploaded fonts.
  • Added text mode for CNC G-code generator.
  • Added pocket as a carve path option for CNC G-code generator.
  • Added options for flipping models in Laser and CNC G-code generator.
  • Added nozzle and bed temperature control on status widget (Don’t forget to pause your work before setting a new target temperature).
  • Improved greyscale effects to produce more uniform speckling.
    Before:
    After:
  • Bugfixes
    • CNC G-code generation errors when using 180° bits
    • Resolved interaction conflicts on mouse events
  • User interactions improvements
Option 2
Option 2
Start Snapmakerjs on Linux:
  • Add your user to group dialout: sudo usermod -aG dialout [your username]
  • Start executable: ./snapmakerjs (.tar.gz version) or snapmakerjs (.deb version)
Or simply start executable with sudo ./snapmakerjs or sudo snapmakerjs
#44
Aug. 20: v2.6.0
@all
Thank you for your suggestions to make Snapmakerjs better. Here comes the latest version. Your feedback is always appreciated. Please post bug reports and feedback to this topic: Bug Reports and Feedback for Snapmakerjs v2.6.X =)
Release Note
Changelog:
  • Added Undo/Redo functions to laser G-code generator.
  • Added machine modal state in machine status widget.
  • In 3D printing G-code generator, we moved down adhesion and support sections to printing configurations; Added configurable line count for skirt, brim, raft adhesions; Added 3 selectable support patterns: Line, Grid, Zigzag.
  • Reworked material configurations, now you can duplicate existing material configurations and make changes on them.
  • Bugfix: fixed the bug that laser is not turning on when resuming from a pause on software.
  • Bugfix: fixed laser Multi-Pass wrong movements after engraving finished.
  • Other minor changes:
    • Added keyboard shortcut (Command+D / Ctrl+D) to duplicate selected 3D model.
    • Added jog speed input in Axes widget.
    • Reduced initial layer printing speed to 18mm/s for out-of-box better results
Option 2
Option 2
To start Snapmakerjs on Linux:
Snapmakerjs v2.5.5 Beta Testing
Snapmakerjs starts briefly and then crashes immediately
#45
Sep. 3: v2.6.1
@all
Release Note
Changelog:
  • Refactored models and G-code parser.
  • Reworked on outline calculation algorithm and even-old rule calculation on CNC G-code generator.
  • Fixed a bug that unable to preview G-code after any failed preview.
  • Fixed wall line count calculation errors for 3D printing.
  • Fixed multi-line text height calculation errors.
Snapmakerjs for macOS
Snapmakerjs for Windows 64-bit
Snapmakerjs for Windows 32-bit
Snapmakerjs for Linux 64-bit
Option 1 (recommended)
Option 2
Snapmakerjs for Linux 32-bit
Option 2
Hint: To start Snapmakerjs on Linux, you need to:
  • Start executable: snapmakerjs (.deb version) or ./snapmakerjs (compressed version)
Snapmaker, open source and Linux
#46
Dec. 25: v2.7.0
@all
Release Note
This release mainly solves the notarization problem of macOS Catalina.
Changelog:
  • Notarized application in order to work on macOS Catalina.
  • 3DP: Added 2 support configurations, as follows:
    • “Support Overhang Angle” to specify minimum angle of which support is added.
    • “Support Density” to adjust the density of support.
  • Fixed a bug that tool head model is not moving along with G-code sent progress.
Option 2
Option 2
#47
Jan. 2: v2.7.1
@all
Release Note
Changelog:
  • Fixed a SVG numeric parsing problem.
Option 2
Option 2
SnapmakerJS not translating SVGs properly
