Dec. 5: V2.5.0
@all
Thank you for your suggestions to make Snapmakerjs better. Here comes the latest version. Your feedback is always appreciated. Please post bug reports and feedback to this topic: Bug Reports and Feedback for Snapmakerjs V2.5.X =)
Release Note
Change Log:
- Better preview results when generating G-codes for laser engraving and CNC carving: when clicking “Preview”, the software will apply parameters directly on the image to make the preview closer to the final result.
- Added Pause and Resume feature. This feature is available only when the printer is printing using the USB cable.
- Added the “Lay Flat Selected Model” feature.
- Added the Enclosure page in the Settings tab. You can turn on / off the Door Detection feature according to your hardware setup. When you don’t need the Open-and-pause-laser feature on the Enclosure V1.1, you need to turn off the Door Detection feature; when you need the Open-and-pause-laser feature on the Enclosure V1.1, you need to turn on the Door Detection feature. Please note that this feature can only be used when the firmware is upgraded to V2.7. Follow these steps to change the settings:
- Connect Snapmakerjs to the Snapmaker
- Go to Settings → Enclosure → Door Detection and turn it on / off.
- Bugfix: Fixed Linux image upload issue across different partitions.
Snapmakerjs for Mac OS
- Download: Snapmakerjs-2.5.0-mac-x64.dmg
Snapmakerjs for Windows 64 bit
- Download: Snapmakerjs-2.5.0-win-x64.exe
Snapmakerjs for Windows 32 bit
- Download: Snapmakerjs-2.5.0-win-ia32.exe
Snapmakerjs for Linux 64 bit
Option 1 (Recommended)
- Download: Snapmakerjs-2.5.0-linux-amd64.deb
- note: sudo ./snapmakerjs # Must use sudo or serialport can’t be accessed.
Option 2
- Download: Snapmakerjs-2.5.0-linux-x64.tar.gz
- note: sudo snapmakerjs # Must use sudo or serialport can’t be accessed.
Snapmakerjs for Linux 32 bit
- Download: Snapmakerjs-2.5.0-linux-i386.deb
Option 2
- Download: Snapmakerjs-2.5.0-linux-ia32.tar.gz
