Dot-matrix automatically inserted on SVG imported pictures
#1
just a few days ago, I used the laser-module to engrave a text on wood - I imported an SVG-vector-graphic for this.
SnapmakerJS_Punktequadrat
Automatically, a dot-matrix-square was added to my paths. What is this for, can this be switched off in any way? Sorry, but I did not find any information in the manual or such…
thanks in advance for any help,
torge.
#2
The dot matrix probably is invisible part in your SVG file, you can open your SVG file with text editor and remove that part.
#3
hi parachvte!
i have imported the svg-file to adobe ilustrator (the same program i created it with) as well as inkscape. in both applications the dot-matrix-square was not displayed. i have looked at the NC-file with a text editor and here the square is probably present (because it is written by the machine), only that one cannot see and delete it easily.
any more ideas to this?
#4
Just a suggestion, try to cut wanted image and paste in new file. This could solve the problem. I had similar issues and was solved by this.
#5
thx parachvte - i couldn’t find any hidden layer…
…BUT i found out that by saving the file as a SVG 1.1 or SVG 1.2 TINY (in adobe illustrator CS 3), the dot-matrix-square does not show up anymore.
anyway i still don’t understand what this is for…
