# Does PID Tuning work on SM2?
**URL:** <https://forum.snapmaker.com/t/does-pid-tuning-work-on-sm2/7076>\
**Created:** [June 12, 2020, 5:36pm UTC](https://forum.snapmaker.com/t/does-pid-tuning-work-on-sm2/7076 "2020-06-12T17:36:06Z")\
**Showing post:** 3
**Post date:** [August 16, 2020, 10:10am UTC](https://forum.snapmaker.com/t/does-pid-tuning-work-on-sm2/7076/3 "2020-08-16T10:10:07Z")
Haven´t tried pid-tuning yet.- There was no need.
> [@3d Print Guide\_Walk Through](https://forum.snapmaker.com/t/3d-print-guide-walk-through/5945/1):
> M303 PID AUTOTUNING
> If you want to pid tune, you should generally think about which sort of filament do you take the most of your prints. I´m using the most of the time PLA at about 210°C with no printpartcooler.
> [PID autotune | Marlin Firmware](https://marlinfw.org/docs/gcode/M303.html)
> NOZZLE PID AUTOTUNE
> If you use the most of the time a printpartcooler i suggest you to run the fan at 100% for pid tuning.
> For running the Partcoolerfan with 100% enter: M106
> If you want to turn it off again enter: M107
> Enter following to the terminal for pid tuning: M303 C10 E0 S210
> [M303=PID Tuning] [C10=amount of testing(10times)] [E0=Extruder] [S210=Temperature]
> If you have done so, you have to wait a few minutes, till following response comes (Your values will be different!):
> Recv: Classic PID
> Recv: Kp: 9.06
> Recv: Ki: 1.57
> Recv: Kd: 13.05
> Recv: PID Autotune finished! Put the last Kp, Ki and Kd constants from below into Configuration.h
> Now you see my new P9.06 I1.57 D13.05 values.
> To write it to the machine we enter: M301 P9.06 I1.57 D13.05 E0
> Now you have to save your configuration entering: M500
> BED PID AUTOTUNE
> this is currently not available, you would have to edit the firmware configuration.
_[View the full topic](https://forum.snapmaker.com/t/does-pid-tuning-work-on-sm2/7076)._
