I have the Snapmaker 2.0 A350/A350T/F350. I recently upgraded Luban to 4.10.1 and the Firmware to 1.18.1_20231103 and the Touchscreen is 4.6.3. Using the 40 watt Laser Head.
Since that upgrade my DFX files are importing at 10% of there correct size. This includes older DXF files that have imported perfectly in the past, If I move the decimal over one spot, ie multiple by 10, then it is the correct size.
What is causing this? Should I drop back to an older revision and if so which one is suggested?
Note: I dropped Luban back to 4.9.1 and now the DXF files import properly. Tried 4.10.0 to narrow it down further, the problem returned. So it appears the ābugā is 4.10.X
Thanks in Advance for any Assistance.
