Hide defective print head to keep using printer until repair
I recently encountered an issue with a clogged print head using TPU. An error message appeared, and the print head needed to be repaired. Once the print head is removed, the entire printer becomes unusable.
It would be great if you could disable individual print heads in the menu, allowing you to continue using the printer with the remaining print heads during the waiting time for a replacement part.
We definitely need this.
Tags “U1” and “Firmware” added
This can deff be done as its already available in the PAXX FW
Even without Paxx, this can be done using fluidd
https://wiki.snapmaker.com/en/snapmaker_u1/troubleshooting/bypass_a_faulty_toolhead
It would be nice if it’s done through screen menu
