Controller holder sharp - cutting into cable
I just noticed that the cable on my controller is starting to show wear and has actually sliced through so I can see the wires.
The problem is that the holder for the controller is actually sharp along the edges.
I wrapped the edges of the holder and cable with electrical tape for now. I’ll file them down at some point.
Unfortunately they didn’t make the cable detachable and use usb-c for both ends and the strain relief is not well designed or of high quality either.
If you’re like me and you’re always removing and replacing the controller because you like to move around to check boundaries with the controller in your hand, I suggest you take a look at your cable. I’d suggest either some electrical tape or shrink wrap to help protect it.
