Small font size setting
hi
Snapmaker U1 (0.4 nozzle)
What is the best configuration for printing SMALL letters on a keychain?
This is about design as well as Orca settings, so I have moved it.
First you need a very simple typeface (font), which is clear and has thick strokes with rounded corners. The smallest you can print is where the strokes are no less than the nozzle diameter.
Next I recommend that the text is printed downwards on the build plate (not on the top surface), preferably on a smooth plate (but a textured plate produces an interesting effect), and the text needs to be at least 2 layers think (perhaps more if the filament is translucent).
Make the layer 1 print speed very, very slow, otherwise the amount of detail in the text will result in the print failing, and set the order of printing so the background (not the text) prints first.
Others might disagree, but I have found this method produces much nicer text than printing it on the top surface. It is possible to print finer text on vertical surfaces, but if you want the text to look good this is the way to go.
Small fine text and a 0.4 nozzle don’t really go that well together is the true answer - you really need a 0.2 nozzle to get the best
@CrazyIvan has given you the best tips that I could think of, although you don’t say how “small” small is?.. It will be about juggling the size of the keychain vs size of font vs font style
Sorry if thats not alot of help
I’ve done 6mm, very legible, using “Gotham Rounded”, but I could probably go smaller.
Not saying it can’t be done, but as I said to the OP, how small is small?
bico 0.4 the setting to improve these small letters “Brand Gifts”
thank you
Far too small to get much better than that.
For that size you are going to need a 0.2 nozzle, can you sacrifice the size of the BG being abit smaller thus giving you room to move the small text up and make it larger?
Or maybe making the wording curved to follow the outside edge which should allow it to be larger?
Another option is to move the white ring out to the very edge or get rid of it altogether again to free up space to make the wording bigger
EDIT: It looks like 2 separate pieces in the pic, is it a trolley token or such like?
