Hello,
I’m trying to cut the following model, but the result is wrong.
Snapmaker 2 A350
Machine firmware v1.10.0_20200723
Snapmaker Luban v3.7.0 (3.7.0.331)
Fusion 360 v2.0.8809
Hello,
Snapmaker 2 A350
Can’t tell from that.
Post the fusion and g-code/cnc.
Have you tried using camotics or ncviewer.com to see what it’s doing?
Here’s the g-code.
I run it in ncviewer.com and it looks good.
I suppose it is a machine error of some kind.
1.cnc (470.3 KB)
Looks fine in Luban.
You’ve had success with other cnc from fusion?
Maybe try exporting g-code from fusion again. Quit Luban and import to Luban again?
Or try from a usb?
I’ve had some weird things show up and go away when I’ve redone them.
I think I would start it directly from the USB. I couldn’t try anything yet, because I’ve got no machine. But I think @jepho had some problems when trying to laser engrave files he created without Luban but was lasering with Luban.
Is that one sliced model or two? I mean, when you loaded the model, did you load one model or two models? I’ve noticed what I think is an issue when printing two models.
And still being a novice, that could be me missing some detail.
