CNC bed - tip to stop inserts coming out
What depth is your spoilboard? I am using an 18mm board with M6 inserts. It is said that they need a 9mm hole but you can get away with 8mm if you want. I am using 10mm inserts from underneath the wasteboard. When screwing the M6 cap heads into them to hold the clamps, it pulls the insert up into the hole further.
