ChromaMatter — Sorca CM brings colour editing and cutting into Snapmaker Orca
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
Ponkichi0718
Project name
ChromaMatter - Sorca CM
Project URL
Project cover
Project Category
3D Model Editor
Project Summary
Sorca CM lets me start with a coloured model or a blank mesh, choose four filaments for my Snapmaker U1, then paint, cut and slice in one place. I started ChromaMatter because I wanted that control over AI-generated models. My Phase 1 entry was a standalone colour tool. I later brought it into my own build of Snapmaker Orca, first shared as Orca with CM.
In v1.1 I can paint a figure in Flat Color, use the painted regions to cut it into parts, then transfer Full Spectrum colours onto those same parts. Core/Shell grew out of trying to print softer shadows by putting black beneath a coloured surface. The egg in the video takes that idea further. It looks almost white until I switch on the light and the red and blue pattern shows through.
If based on an existing project — your independent contribution
ChromaMatter received Third Prize in Phase 1. I built the original tool to prepare coloured GLB and OBJ models for printing with Full Spectrum. In the Orca with CM builds, and then in Sorca CM v1.0 on 24 October, I brought that work into Snapmaker Orca 2.4.0. Full Spectrum supplies the mixing method. My work connects the model’s colours, the edits I make by hand and the materials I put inside each wall.
I released v1.1 on 3 November during Phase 2. I improved how the fill tool follows a surface and picks up spots I missed. For parts selected by colour, I can adjust the cut cap and choose which side keeps the peg. If a cut part can be matched to the original model, I can reapply its Full Spectrum colours without setting up the cut again. I also fixed a case where four-material parts were counted as five and could not be sliced.
Core/Shell started with black filament leaving scattered lines where I wanted soft shadows. I tried putting the black inside and varying the thickness of the coloured shell. The light-up egg is an experiment with the wall tools that grew out of that work.
Original ChromaMatter project — GitHub - Ponkichi0718/ChromaMatter: Sorca CM — colour editing, mixing, material layers and cutting inside Snapmaker Orca. Built on ChromaMatter, for Windows, Apple Silicon Mac and Linux. · GitHub
Snapmaker Orca — GitHub - Snapmaker/OrcaSlicer: G-code generator for 3D printers (Bambu, Prusa, Voron, VzBot, RatRig, Creality, etc.) · GitHub
v1.1 release and corresponding source — Release Sorca CM v1.1 · Ponkichi0718/ChromaMatter · GitHub
Open Source Status
Open Source
Please specify the open source license used by this project
GNU Affero General Public License v3 (AGPLv3) for the Snapmaker Orca-based slicer. Third-party components retain their respective licences.
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Improvement / optimization based on an existing project
ChromaMatter, my Phase 1 Third Prize project, began as a standalone tool for preparing coloured 3D models for the Snapmaker U1. From the start, I wanted to choose how a model was coloured and where to split it for printing. I brought that work into my own build of Snapmaker Orca 2.4.0, initially shared as Orca with CM.
On 24 October, I released that integrated application as Sorca CM v1.0. I could import a coloured GLB or OBJ, choose four filaments, adjust the colours and shading by hand, prepare the parts and slice the model in the same application. ChromaMatter remains the project name, and Sorca CM is the application.
I use Snapmaker Orca’s existing Full Spectrum mixing system. My Core/Shell work began when black filament left scattered lines where I wanted soft shadows. I moved the black beneath a coloured shell and varied the shell thickness to control how much black showed through. Being able to arrange materials through the wall also made experiments like the light-up egg possible.
On 3 November, during Phase 2, I released v1.1 with improvements to angle-based filling, cut caps and attached pegs. On the Vegeta model, I could define the cuts using the regions I had painted in Flat Color, then transfer Full Spectrum colours onto the matching cut parts without having to set up the cuts again.
Is it a paid project?
No
Here’s a four-minute tour of Sorca CM. If you’re curious about cutting, jump to 2:01. I use the painted regions on Vegeta to separate the head, make a cap and choose which part keeps the peg. At 2:47 you can see the Full Spectrum colours go back onto the cut parts. The cut stays where I put it.
At 3:36 you can see the printed egg with the light off. Four seconds later I switch it on. From the outside in, the wall is clear filament, white, then a Full Spectrum mix of red, blue and white around a hollow centre. I’m still working on the surface finish, but I wanted to share what those layers look like with light coming through them.
0:04 — Import a coloured model or a blank mesh
0:57 — Paint on the model
1:42 — Try monochrome, manga shading and other colour treatments
2:01 — Turn painted regions into parts
2:47 — Transfer Full Spectrum colours to the cut parts
3:03 — Look inside the walls and see the egg light up
3:48 — Choose filaments, plan plates and print a colour chart
