Maybe it exists already but I can’t find it. It would be helpful to have a preheat function so the bed and fan can turn on and stay on until the chamber is heat soaked before printing is initiated.
I reheat my bed from Fluidd using the presets, which you will need to setup yourself. Beware that 5 minutes after target temp is reached it will turn off, safety feature.
That’s what I’m talking about. We can manually change the dwell time to whatever so it stays on, because 5 minutes is annoying. My ask is that they make it an official feature instead of having to play with the config files so we don’t have to reset the bed temp every 5 minutes.
Exactly, and making it an official feature means it wouldn’t be on us
I don’t think you understand. It wouldn’t be outside of what it’s designed to do. The bed already stays on for days at a time during a print. It’s also designed to hold heat for higher temp printing and to do that it needs to preheat. I’m not here to argue, I’m here to ask for a feature from Snapmaker, and I’ll wait for what they say.
In the presets in Fluidd you should be able to over ride the 5 minutes using gcode.
This is similar: Using U1 For Filament Drying
Hi, thank you very much for the feedback. I’ve forwarded your request to the engineers for further evaluation.
Quick question: would you prefer this preheat / heat soak feature to be controllable directly on the U1 touchscreen?
With the official top cover, Snapmaker Orca already includes a chamber preheat workflow for high-temperature materials like ABS and ASA when using internal circulation mode.
- When preheating starts, the exhaust fan automatically turns off and the internal circulation fan switches on.
- Before printing, the printer will wait for the chamber to reach the target temperature:
- It keeps waiting as long as the chamber temperature is still rising.
- If the chamber temperature stops increasing for a set period (default 3 minutes), it exits preheat and proceeds with the print job.
So the software team has already built in a chamber preheat mechanism, though it is not yet complete for your case.
That would be very useful for filament drying.
I think it would be helpful on screen for filament drying. You mention the top hat coming with the preheat function, so I can wait for that when it arrives in November
I created macros to add to chamber pre-heating and filament drying to Fluidd, but they also should work in Mainsail.
These macros are for use with Paxx12 firmware: Temp_Control_No_Chamber_Heater_Pax12
These macros are for use with stock firmware: Temp_Control_No_Chamber_Heater_Stock_Firmware
Read the README file before using one: Klipper-Configuration-Additions-for-Snapmaker-U1/README.md at main · C8forT/Klipper-Configuration-Additions-for-Snapmaker-U1 · GitHub
I also have macros there for use with the Panda Breath for chamber pre-heating and filament drying.
You can create presets in Fluidd to heat the bed
I think doing it that way times out after 5 minutes? But even if they don’t, the above macros are far more sophisticated.
Yes, the reason I created the macros were due to timeout issues when manually setting the temperatures in Fluidd. I’m using the Paxx12 firmware and a Panda Breath with DragonBreath firmware, which was my starting point. Those macros have been working well for me.
I figured other people may find them useful, but may not have the same configuration I am using. So, I used ChatGPT to convert my macros to other configurations, e.g., using stock firmware, no chamber heater, etc. Perhaps they will be useful.
