Camera not capturing entire build plate
How do I make it so that the camera captures the entire build plate, centered?
I have everything perfected for camera capture so that it works great, EXCEPT it does not capture the entire build plate. It is always skewed to one side.
I set work origin to dead center on build plate then put my wood down with dead center also aligned.
Image capture does not capture all the available real estate on the build plate and what it does capture is skewed to one side.
Thanks in advance
I have the same issue.
The reason no-one has answered this is because there isn’t a good solution.
You may have something wrong with your camera, (check that it looks like it’s mounted flush and not askew) or it’s probably just that camera capture isn’t very good.
Try contacting support.
