Camera calibration crashes into bed
Running camera calibration after updating to firmware 4.4.11 the module moves down into bed. It is moving like it creating the square but never fires the laser and if it did would be far too close as it is rubbing the bed.
Tried resetting everything, same problem.
Found the problem, short between the headsets. For anyone else coming across this situation. You must perform the calibrations in a certain order.
  1. Calibrate the toolhead focus.
  2. Calibrate the measurement next
  3. Lastly, do the camera calibration
As for the laser not firing, it was the enclosure door even though I had set it to ignore the door.
