Beam interlocking behaving weird
I’m trying to print a circular bumper for a door that has to screw on a plate that is screwed to a wall.
I tried an “All TPU” method, but I can’t seem to get the threads to engage, so it’s a no go. I then split the main bumper component to get :
  • A PLA plate screwed to the wall
  • A bumper made of PLA (bottom threaded section - pink) and TPU (bumper section - black).
For this, I used the Beam interlocking functionality, but I’m rather puzzled at the results.
Default beam interlocking settings are used:
  • Beam width:0,8mm
  • Layers: 2
  • Depth: 2
With beam Interlocking disabled, last PLA layer is 29, then from layer 30 on, it’s TPU.
With beam interlocking enabled, the interlocking starts at Layer 25 :
Layer 24:
  • 25 and 26: 1 direction
  • 27 and 28 : 90° from previous 2 layers
  • 29 : Almost all PLA
  • 30: Almost all TPU
I’m really puzzled by this behavior…
  1. Starting at Layer 25 doesn’t seem correct with a depth of 2 (As I understand it, it should go 28-29-30-31
  2. Having two “full” layers (29 and 30) in different materials totally defeats the purpose of beam interlocking…
I’ve used beam interlocking in the past and it worked great,… Not sure if I’m missing something or if it’s an issue with the feature itself…
Other parameters include:
  • Wall loops: 2
  • Top surface pattern: monotonic (changing from concentric didn’t change anything)
  • Top shell layers: 5
  • Bottom surface pattern: Monotonic
  • Bottom shell layers: 3
  • 15% infill
Any advice would be welcome…
This doesn’t help you, but as a general comment I would rather design the interlocking in CAD than rely on the slicer.
Indeed it doesn’t help… :smiley:
But I ended up solving the issue playing with top surface layer count and got good bond between layers.
5-3 (top/bottom) did not work, 3-3 worked but 4-4 didn’t either… quite weird.
