Artisan ret Code
is there anywhere a description of the rather cryptic error codes / retCodes?
I have just the problem, that my printer doesn’t want to start a job - the calibration worked fine, no problem, G-code has been generated and transferred to the machine. When I want to start the job, I get back the message “Unable to start the job, please check your machine settings and try again. retCode:13”. Any help??
Here you go:
https://wiki.snapmaker.com/en/snapmaker_artisan/troubleshooting/Touchscreen_error_code_reference
Can we have this for Snapmaker 2.0, i.e. such a detailed reporting on the touchscreen? That would be nice…
Thats very useful, many thanks!
But… it’s not necessarily answering my initial question: I have a complete different message on the display: there’s no “Error”, there’s a message “Unable to start the job, please check your machine settings and try again. retCode:13”
In this case if you dont find anything in the artisan wiki you have to email support.
Did you select the correct machine size in Luban?
Share your gcode pls.
@Hauke, not sure if you know, i am a user like you and no snapmaker staff :beers:
Thanks Chris, good you’ve mentioned that you’re not a Snapmaker employee :slight_smile: I have already reached out to support, but no answer… many thanks for your help!
