# Artisan CNC Tool Change G-Code
**URL:** <https://forum.snapmaker.com/t/artisan-cnc-tool-change-g-code/30949>\
**Category:** Artisan (3-in-1)\
**Tags:** 3D\_Models, Gcode\
**Created:** [April 19, 2023, 7:50pm UTC](https://forum.snapmaker.com/t/artisan-cnc-tool-change-g-code/30949 "2023-04-19T19:50:04Z")\
**Showing post:** 2
**Post date:** [April 20, 2023, 4:26am UTC](https://forum.snapmaker.com/t/artisan-cnc-tool-change-g-code/30949/2 "2023-04-20T04:26:07Z")
I am a member like you and no snapmaker staff.
I am not so exerienced with cnc also. Never did a toolchange while in a cnc process, i carved it in multiple gcodes.
I would suggest to request this feature by email to support, you should also request M600 for 3d printing which maybe could your solving command in cnc also (it simply does the same, if its true).
One more have a look at this and maybe you are able to find here further information or a new postprocessor 😉
Sorry i see you did your way there, so its just for pointing out.
> [@Available Now: New post-processor, tool library, machine configurations, for Fusion 360](https://forum.snapmaker.com/t/available-now-new-post-processor-tool-library-machine-configurations-for-fusion-360/24955/46):
> Artisan owner here as well. I’m just starting to deep dive into the CNC module and have the same request as above. FYI, super appreciate your work - it’s what makes the world wide web go round. I’m currently CADing a dummy model of the machine just to better orient myself in space while in the Manufacture setup of Fusion. I created a machine in the library with the most basic info, but it was based on an “Autodesk generic 3-axis”, so there’s a lot wrong (no build plate listed, no rotary axis, e…
Maybe @Tracy could pick the request of cnc-toolchange up?
_[View the full topic](https://forum.snapmaker.com/t/artisan-cnc-tool-change-g-code/30949)._
