Hello Friends!
After spending several hours fine-tuning settings to get a good first layer with PETG I have developed a different issue. The walls of the model (vertical surfaces) are wavy, not along the X or Y axis, but along the Z-axis. I have not seen this before now. I spent the last hour or so scanning posts here and understand that certain print speeds may be at a speed that can cause a resonance from the stepper motors. I’m retrying a print with slower speeds just to see if that is the issue but I thought I would post a photo here for feedback as well.
Settings for this print:
Slicer: Cura
Material: Overture PETG
Print Speed: 50 mm/sec
Print Temp: 235
Bed Temp: 90
Cooling Fan: OFF
Layer Height: 0.2 mm
Thank you in advance for your thoughts!
