Allow negative brim distance
:white_check_mark: I have searched this category and verified this feature request does NOT already exist.
on
1. Feature Summary
With Elephant’s Foot Compensation (EFC) enabled, the calculated brim distance leaves a gap between the brim and part. If a negative brim distance was permitted, it would allow the user to compensate for this, without introducing a huge burden of code.
2. Why this feature is needed
See Orca discussion for full background: https://github.com/OrcaSlicer/OrcaSlicer/pull/11699
Basically, when EFC is enabled, (default is 0.15mm) that distance is not applied to the brim distance, and there will be a small gap - perhaps not the full 0.15mm - due to material squish and physics, but it is noticeable, and defeats the purpose of the brim.
3. Expected outcome
if a user enters a negative brim gap, the slicer does not reject it, and the brim is thus moved towards the part by that amount.
Affected Products
Snapmaker Orca/App
yeah the efc/brim gap mismatch tracks, hopefully a negative entry just means the brim hugs the part instead
You need to also vote on this @alaorath at the top
