ABS Help
Hi, I am frustrated trying to get ABS to not warp and I need some help. PLA and PETG print very nicely but I have not been able to get ABS to not lift in 1 or 2 corners. I am experienced with ABS/ASA, I have built 2 Vorons and have an X1c and am able to print it just fine on them. The U1 has the OEM top cover, I am using the OEM PEI build plate, and I am as sure as I can be that I have the slicer configured for ABS standard print quality. I used my FLIR and I do see a lot of variance in bed temp with hot spots. I have looked at the carbon fiber and funsor aluminum bed mods but before I spend another $170 is anyone else having these issues? Again I’m not a novice so please no suggestions like level the bed or use IPA to clean the buildplate, I just really need some assistance.
Thank you.
Here is what I’m seeing. In thinking about this, instead of replacing the whole bed, someone make a mic6 toolplate that just sits right on top, I would think that would make temps much more consistent. That said, I’m not sure this is the root cause of my ABS issues, just the only thing quantitative I have found so far.
Hi, Which ABS filament brand/type are you using? Could you also share some pictures of the prints?
Have you tried raising the bed temperature? The U1 does run somewhat cooler at the four corners due to its heat distribution, so you can raise the bed setpoint accordingly. If you’re comfortable doing so, you can raise the bed’s low-temperature limit in Fluidd up to 110°C, then wait for the bed temperature to stabilize before starting the print.
We’d also recommend applying glue to improve adhesion.
Best regards.
Thank you for the reply although I’m not sure how much experience you have with the U1. The hotbed is software locked to a max of 100c so without editing the printer.cfg and possibly voiding the warranty, 110 is not an option. That said, The bed is getting very close to 100c which is good for ABS. I also run a heatsoak macro which sets the bed to 100c and runs the chamber fan for 20 minutes, I have not used glue sice the old days of glass beds and bed slingers. My vorons which print ABS perfectly reach right at 100c, although with a much more uniform temp. I use several vendors for ABS but these exact spools work on the voron and bambu but warp on the U1. close temps, same slicer, same filament, same buildplate material, but warping on the U1. Photos below.
Are you using the standard textured PEI build plate? If so I found the adhesion levels to be really poor with it (being polite) and that a no-name £7 one from aliexpress cured 99% warping issues for me /personally/
I have the same experience with ABS warping in the front corners. Bed at 98C and first layer temp of 240C. Increasing bed causes the white stress marks.
After seeing the thermal pictures, I might try rotating the model (box bottom) 45deg to coincide the corners on the heater leads.
A thick aluminum plate might distribute heat more evenly… but then are back to using binder clips to secure the stack to the bed?
Thanks for the reply. I’m using the Snapmaker Smooth PEI plate which I wash with detergent before each print. I use smooth PEI on all my printers. I guess I should probably run the textured as a point of comparison.
Good point, I hadn’t considered the plate alignment pins.
Plate alignment pins, magnetic clamps, and calibration cup.
I had envisioned that it would merely sit on top of the existing bed and be removeable leaving the alignment cup exposed. It was just a thought to test idf it is the poor heat distribution on the U1 is the root cause of the ABS defects and not a permanent solution. There are both milled aluminum and carbon fiber hotbeds available but $170 is a bit much just to test and see if that fixes the problem. If Ican’t fix this, I guess I’ll gibe up, the new Bambu H3C seems to check all the boxes so maybe I’ll just upgrade my X1c and scrap the U1. It’s a shame, the U1 does everything else so well and with QOL mods like multiace, it really is a good setup. For my use cases I have to have ABS/ASA print well though.
Magnets will stick to the build plate, but may not tack it on to an aluminum plate.
Back in the day… it was common to use binder clips (with the wired extenders removed) to hold glass plates to the heater bed.
$2400 is a little rich for my blood… but would be nice.
I reliably printed ABS on an open bed slinger in a drafty basement… so it has to be possible with the U1. :grinning_face:
Have you tried a brim? Make it 10mm, adjust so no gap to the model. If that doesn’t work, increase the thickness of the brim - the hack is to use a multi-layer skirt, this makes the brim multiple layers also. The skirt may need to be touching the model.
I think you misunderstood me. I listed the things that would be missing if an aluminium plate were simply added on top of the U1’s bed.
I’m aware of that, but access would not be easy in the U1’s cabinet.
Yes I misunderstood.
It would be possible to put binder clips at the front and back of the U1 bed…
I’m going to play devils advocate here…
For the price the U1 is a really good hobbyist/craft market seller printer - but for anything remotely serious the cracks appear, printing PLA & PETG is just fine the rest is sketchy at best
The reason I say this as the U1 although marketed for the likes of ABS/TPU never did & still doesn’t ship with a lid, any printer claiming this should be enclosed fullstop. Secondly its built like a sieve, there are so any holes and loose panels that I wouldn’t print anything remotely toxic in a U1 inside my house as its never going to filter correctly & I’d rather have my health than trying to sue for damages to my lungs etc
But! when you then look to the likes of BL & Prusa as examples those machines are 2 to 3 times the price of a U1 & built quality is on a different level to the U1 hence the price differences
So horses for courses as they say…
All valid points and you are 100% correct that the cost of the U1 is at a very different price point than the Bambu, which by the way I am not a fan of their business practices. I still feel that it is a shame that the ABS performance is limited, be i uneven heatbed temps, undesirable airflow, or whatever. I would absolutely be willing to put hundreds into solving this if we could find the definitive root cause as other than this I really like the printer.
I see layer lines which means your leveling could be a bit more tight. This could cause over extrusion on the first layer but also more squish and adhesion.
Thanks for the reply. IMHO, you will always see layer lines, depends on the lighting as to how pronounced they are. Squish though is a good point, on my Vorons, I usually tend to a little more squish than optimal for the reason you mention. I just always let the U1 do its thing automatically after calibration and thought the 1st layer was a little high for my taste, is there a manual override? I guess I could just issue a manual z offset adjust through the UI after the print starts. Anyone do this or have any resource discussing manual z offset adjust after auto-calibration? Thanks again for the reply, this might be something to dig into.
I think the U1 with the Top Cover prints ABS just fine. I’ve had my fair share of struggles printing ABS on different printers in cold basements. I’ve successfully printed all the printed parts for a Voron on a bed slinger. So I may have a slight edge on tuning the filament for the printer.
The U1 turns out ABS prints just fine, even large hollow cubes which are very challenging.
OP try these settings:
  • Bed temp: 100C (or 110 is better if you know how to edit the printer.cfg)
  • Extrusion temp: First Layer 240, Rest 255
  • Cooling: 10-15% after the 10th layer
  • Optionally: Use a minimal Z-hop distance… I forget the exact value, but I’m at .5mm
  • Use a 10mm brim, make sure the gap to the model is set to 0. I haven’t had to do this, but you can make the brim stronger by enabling a multi-layer skirt touching the model… this somehow makes the brim multi-layer also. The multilayer brim just increases the contact with the model and provides a stronger base.
  • Heat soak the bed as much as possible… enable the Dynamic Flow Calibration and Auto Bed Level. These options will turn the bed on for the duration it takes to run the two options. I find if you turn the bed on to 100C 5+ minutes before the start of the print with these options, the chamber temp will reach 46C. During the print the chamber temp will reach 54C.
Off-topic: can I ask how well you find the filtering performs? Are you printing ABS in a domestic environment?
