# A350 will not connect after an interrupted firmware update
**URL:** <https://forum.snapmaker.com/t/a350-will-not-connect-after-an-interrupted-firmware-update/32604>\
**Created:** [August 20, 2023, 10:25am UTC](https://forum.snapmaker.com/t/a350-will-not-connect-after-an-interrupted-firmware-update/32604 "2023-08-20T10:25:06Z")\
**Showing post:** 3
**Post date:** [August 21, 2023, 6:15am UTC](https://forum.snapmaker.com/t/a350-will-not-connect-after-an-interrupted-firmware-update/32604/3 "2023-08-21T06:15:09Z")
Have you tried updating the firmware again? From a flash drive?
Or have you tried a factory reset and then updating firmware?
> [@Reset to factory settings?](https://forum.snapmaker.com/t/reset-to-factory-settings/23058/3):
> To perform a **Full Factory Reset** to the currently installed version of firmware, you need to **Factory Reset** both the **Touch Pad** and the **Controller** :
> 1. Connect your computer to the **Controller** via USB (must be USB).
> 2. Issue an `M502` factory reset to the **Controller**.
> 3. Put the **Touch Pad** into **Developer Mode**. This is done via the **About** page, and tapping the printer image 5 times. You’ll see a popup window when it changes modes.
> 4. Reset and clear out the **Touch Pad**. You will need to navigate around to find this, as it seems to change with each version of firmware.
> 5. Reinstall the currently installed version of firmware from a USB drive (must be from a USB drive). All versions of the firmware are available in the [Snapmaker 2.0 Firmware Updates and Downloads](https://forum.snapmaker.com/t/snapmaker-2-0-firmware-updates-and-downloads/5443) thread.
> 6. Update all of the modules.
_[View the full topic](https://forum.snapmaker.com/t/a350-will-not-connect-after-an-interrupted-firmware-update/32604)._
