Hi, I just finally put my A350 together and built the enclosure. I have everything plugged in properly and did the update to 1.10. Unfortunately I don’t see the enclosure icon and when I got to calibrate the printer its now off by .5 in in x and y and z doesn’t touch the plate. It also asks me to manually correct the 9th position. How can I fix this?
For the last position, you need to set the z-height to about 0.1mm spacing using the calibration card and using the up and down arrows. Then hit save. Also, go into settings, 3D printing, and turn on the 5x5 grid, which will give you more data points.
If you go to settings - about, what firmware is showing up? - if 1.10.x, then you need to check your wiring again, - the enclosure should be plugged into add on port 3.
It is and still no go. Also tried switching the port on the enclosure.
