2W Laser engraving in the wrong place
Hoping someone can help me fix this!
First issue. When I set the crosshairs on the material I want to engrave {i.e. bottom right} and run a boundary, everything works correctly. However, when I start the laser job, the 2w tool head moves to a different location and starts engraving on the platform and not the work piece. I’ve tried setting the work origin at different locations; top left, center, but the same problem occurs. I have reset the controller firmware to factory defaults, and reloaded Luban on my computer, but the same problem occurs. I have tried using my 40w laser, but get the same thing. I have been in contact with the Snapmaker Support Team for about two weeks and haven’t been able to get the problem resolved.
Second issue: After having wrestled with the above issue for a couple weeks, I am now having an issue with Luban connecting from my computer to the controller. Whether I try to connect with WiFi, mini usb cable or thumb drive, the controller doesn’t accept the input.
Although my Artisan 3-1 is still under warranty, I have not received a response from snapmaker when I inquired about getting controller replaced.
This is an older post and maybe its not your machine but try to enter only the M2000 command without the addition for x and y offset to see your values:
You could reload your factory settings by M502 and save it with M500
