# 1064nm Offset Incorrect in Lightburn
**URL:** <https://forum.snapmaker.com/t/1064nm-offset-incorrect-in-lightburn/42279>\
**Category:** Artisan (3-in-1)\
**Created:** [June 18, 2026, 6:44pm UTC](https://forum.snapmaker.com/t/1064nm-offset-incorrect-in-lightburn/42279 "2026-06-18T18:44:45Z")\
**Showing post:** 2
**Author:** ![berni](https://avatars.discourse-cdn.com/v4/letter/b/13edae/32.png) [@berni](https://forum.snapmaker.com/u/berni)\
**Post date:** [June 19, 2026, 2:58pm UTC](https://forum.snapmaker.com/t/1064nm-offset-incorrect-in-lightburn/42279/2 "2026-06-19T14:58:56Z")
Hello. Did you set the laser offset in the machine to 0?
If not, set it to 0, but be sure to note the previously set value.
This guide explains it well:
> [@1064nm IR+20/40W + Lightburn Guide](https://forum.snapmaker.com/t/1064nm-ir-20-40w-lightburn-guide/35954):
> With the new IR laser coming out, I figured testing and guides would follow. Lucky enough, it seems with minimal tweaks, Lightburn works with the new IR just fine. slight_smile So here’s a guide on setting it up fully with Lightburn for auto-focusing and accurate results. Note; while I don’t have the 20/40W lasers, this guide SHOULD work for those as well. CONFIRMED WITH 40W I tested both USB connection, and using my [Drag/Drop files](https://forum.snapmaker.com/t/guide-automatic-start-via-drag-drop/29177) I - Gathering Information You’ll need to find out homing pl…
Best regards, Bernhard
_[View the full topic](https://forum.snapmaker.com/t/1064nm-offset-incorrect-in-lightburn/42279)._
