Laser module pinout
I like to use my old laser module on a DIY MPCNC machine for doing engraving on a wide greater scale (100cmx160cm), using 3rd party software. What is the pinout of the 4-pin connector?
The very basic setup will be nothing more than a manual on/off switch with a CNC program generated gcode, the next more “sophisticated” setup will get a software activated on/off switch.
Hi.
Have you seen this :
and this :
Or did you find out the laser-pinout ?
Might you will share it ?
